- SW Scotland
So I'm looking to make a compressor based on an engine being turned by another. I'm just at the stage of throwing some numbers about in my head to try and get a grasp on what's possible / needed. Here's my calculations so far, anyone care to sanity check for me (@pdg perhaps mate, I know you like this stuff
My power source (props to Mr Migwire) is a Lombardini 15 LD 315 from a lawn tractor; producing 6HP at a continuous service level. I'm sort of rounding the figures a bit to make it easier to play with so don't worry about rounding errors.
From the manual, at 2500 RPM there is ~15Nm of torque. Theoretically an output engine of 600cc displacement (I'm thinking of common motorbike engine sizes) should yield:
But I'm not sure that a wee 6HP motor would turn a 600cc engine, even with gearing 2:1 that still only gives 30Nm - is that enough? I honestly don't have a clue and el google is annoyingly good at providing figures for output but no idea on input.
Assuming I'm not a million miles away, and that's a big assumption, the second part of the question is what engine from the motorbike world would be a good fit for these criteria:
I'm thinking of occasional blasting of small/medium items. Nothing larger than a motorbike chassis for example and most stuff a lot smaller. I'd also like to do a bit of spraying of items that same sort of size range. It'd also be nice to use some air tools on a good supply so I don't end up pitching them out the window.
I await your musings my fellow peeps
Code:
2500 * 0.6 = 1500L
1m3 = 1000L
1500 / 1000 = 1.5m3/min (53ft3/min)
- 400..600cc
- Common - so parts are easy to find and not eye wateringly expensive
- Reliable/rugged - I don't want to have to fettle it constantly
- Four stroke
- Air or liquid cooled but pref liquid
- Any piston arrangement fine but a flat twin is definite bonus
- And of course - cheap!
