It's an interesting idea, I doubt it's much more efficient than AC and smps's powering everything though.Was wondering about a 4 wire system with 5v 12v 24v, as lots of 5v usb then drop the 12 to 6 and 9 and the 24 covers just about anything else with buck–boost converters. Need to find some heavy copper cable and have a play.
What about pumped storage ? how efficient is that ?
I would expect the wear and tear on the pump/turbine to be less than the deterioration in a battery bank.
I live on the side of a mountain so having 2 ponds with a height difference would be easy, use solar to pump it uphill during the day and let it run down at night to meet my power needs.
The smps aren't so bad its all the wall warts with not much more than a transformer, rectifier, smoothing cap feeding a cheap voltage regulator.It's an interesting idea, I doubt it's much more efficient than AC and smps's powering everything though.
I briefly looked into this but there are lots of losses that make it uneconomical on micro scale.What about pumped storage ? how efficient is that ?
Thanks for that, so if I understand that example correctly, 5000 gallons equates to just under 11KW of power in an ideal world. Given that my usual power usage is between 250 and 500Watts, then that would provide me with 5 to 10 hours of supply. So if I did go down this route ideally I'd need a larger water storage system, also to reduce my power requirements as much as possible and have a few KWatts of both solar and wind to do the pumping as well as meet my daytime needs.I briefly looked into this but there are lots of losses that make it uneconomical on micro scale.
a few power stations do it pump it up on a night then during the day at peak demand can generate very quickly whereas a coal fired cannot stop and start . so there's no generation advantage. apart from that its uneconomicalPumping water uphill to generate electricity by letting it fall down again seems particularly inefficient to me.
It's going to take more energy to get it going up than you'll get out of it on the way down, and the pump and generator costs would surely outweigh the price of just using the wind/solar to keep a battery bank charged.
Batteries break down far less than pumps and generators too...
The trouble is that 1000L = 256 US gallons so that equates to 20 IBC's for 5000 gallons!Thanks for that, so if I understand that example correctly, 5000 gallons equates to just under 11KW of power in an ideal world. Given that my usual power usage is between 250 and 500Watts, then that would provide me with 5 to 10 hours of supply. So if I did go down this route ideally I'd need a larger water storage system, also to reduce my power requirements as much as possible and have a few KWatts of both solar and wind to do the pumping as well as meet my daytime needs.
I can see me trying a small scale version of this in the next few years, a couple of IBC containers some pipe, a water turbine/generator and a pump and solar panel to pump it back up during the day.
One advantage with pumped storage is that every time it rains I'll be happy as it'll be free extra energy in the headstock, not that it rains much in Wales![]()
Like Dinorwig "electric mountain"
namely used when the break comes in corrie or the ex factor or any other crap they pump out on tv![]()
also would screw up speed because the B/B and would see it as a poss fault and would keep the speed down." oh, we turn it off at the wall when we're nit using it to save electricity"![]()
is that 4000 not more like 4 million2000 installs (2000 each so 4000 meters)
is that 4000 not more like 4 million![]()
2000 x 2000 = 4milNot read all the comments but I've done around 2000 installs (2000 each so 4000 meters)
