Daft question really, because I think I know the answer already.
But can normal aluminum be welded to magnesium alloy?
I would think not...
If you use Lumiweld rods they can be joined.
Digger6135
Not successfully
Yes my bad. If it is magnesium then it's 6% aluminium etc. From here: http://www.archivesmse.org/vol28_6/2865.pdf
I will test it and the chances are the best bet will be JB Weld after all. Sadly I can't risk a test on this irreplaceable cover!
I can tell you a little story though. Many years ago (!) I was working for the Ministry of Defence, during the Falklands. The biggest problem in those days was the Exocet missile which would skim the surface of the sea at Mach 1 giving you only seconds to detect it and shoot it down. It would penetrate six inches of steel armour plating at anything up to sixty degrees before it would even think about exploding. As often as not, the device would make a bee line for the central control where all the electronic noise was coming from.
We digress. Back in the day, we were building destroyers with an impressive amount of so called top-weight. Towering super structures built way above the height of the hull for no other reason than that it made the ships look impressively evil!
Unfortunately, the only way to have such an impressive, top heavy look is to use a lot of lightweight magnesium alloy and it is true: it will burn. Later designs reduce the bulk of the superstructure...
S.
What's with the picture of a Town class cruiser? The warcanoes with the aluminium superstructure were the type 21s, although aluminium cladding and lining was blamed for higher casualties on type 42s and LSLs as well.I can tell you a little story though. Many years ago (!) I was working for the Ministry of Defence, during the Falklands. The biggest problem in those days was the Exocet missile which would skim the surface of the sea at Mach 1 giving you only seconds to detect it and shoot it down. It would penetrate six inches of steel armour plating at anything up to sixty degrees before it would even think about exploding. As often as not, the device would make a bee line for the central control where all the electronic noise was coming from.
S.
