arther dailey
- England
I will give you 10% profit on that ruff old swindon, now truthfully you dont want it cluttering up your tidy workshop do you.......Arther
I believe they also stamp the number on the machined portion on one of the jaw sides. Wouldn't worry too much about the hole being oval on that plate. That plate doesn't seem to provide any worthwhile support as such for the screw at the best of times, from what I can see, and they manage fine even when the plate goes missing.Very nice, they look like they've been hardened and ground![]()
Picked this Swinden up today. How much is it worth as I was quite happy to have paid £50? Apart from the horrible paint, the vice is in good condition with a bit of damage to the jaw inserts. The rear shaft support is worn and will need bushing. I know the bolts are wrong and the clamp bolt is non-original. Questions to anyone whose taken one apart - should the clamp bolt be a stud and dome nut with spanner? Should there be a 'can' over the rear of the vise to protect it as the new ones on the Swinden web-site? Should there be a serial/date no. somewhere?
Nice Record 84, a very good quality vice![]()
Fifty quid sounds about right if the seller doesn't know what they've got. I'd buy as many as I could for that price. Worth is difficult to say. If someone is looking for a Swindens to restore, anything up to £100 because they will be worth a lot more once they are done and you can sell them to someone who just wants a good working vice.
When you say "rear shaft support" do you mean the main non rotating body? Or do you mean the part of the moving jaw which passes all the way through? The clamping bolt should be a taper hex headed stud with an angled, removable wrench held captive to the bottom of the stud on a chain. Yours has an odd bolt which might have been drilled and tapped to fit. The lightest pressure on that fixing should lock the rotation solid.
All there is on the end is a plain cast cap, held on by two cap head screws and always drilled right up to the edge. There's one in the bottom left of this picture. You should find a date stamp on the side of the jaw face when you clean off the paint.
S.
This one AdamYou do know your vices!!
What where they used for?
This is the description
"Unusual vice with no makers mark but has a sticker with Dohm 167 Victoria Street London, it weighs 8kg has a 7" base is 10" long and 5" high with 4 bolt holes.Very sturdy with 2 x 3/4" dia. support rods, the moving vice jaw is 3" long and 1" deep with a strong gripping surface and a curved central vee groove. It has a brass protective plate that can be swung into place across the jaw to get a softer clamping action. The fixed half of the vice has a 6 position rotary action and has 1 fixed position facing the moving jaw, the other 5 contoured positions are designed to allow vertical clamping of tubular materials from 1/2" to 1 1/4" diameter , the one fixed position has a centralised horizontal and vertical vee slot and has a smooth clamping face"
and a few pics
View attachment 61241 View attachment 61242 View attachment 61243
