- UK
A few people have recently posted questions about controlling distortion during welding; a few have asked me questions by PM, so I'll try to help out a bit.
Whenever you weld something, the weld causes the metal to firstly expand, then as the weld cools, the metal shrinks, but it shrinks slightly more than it expanded. For some jobs, it's not always an issue, but sometimes it can cause problems...such as this job.
These are 200 x 75 channel floor beams. They have tags welded on every 400mm, all the tags are on one side and each have 260mm of weld round them. If we just weld these without pre-setting/pre-bending, or making some allowance for the shrinkage, the channels will bend inwards like bananas making life hard for the lads trying to erect it.
So, the channel is laid out on a spare beam and a packing plate is put in the middle - here the tags point up, and a piece of 12mm plate is used to pack. Clamped down tight each end.
Can see a bit better here, this is only a short beam, 2.4m long, but will still cause problems if it bends. Longer beams need a thicker packer - 25mm for the longer beams.
Clamped up and ready to weld (The trick is to get your clamp on first so the other bloke has to do all the work in dogging it down...
Weld it up, leave the clamps on so it can cool a bit whilst you clean the welds, then clamps off and plate out.
Tadaaaa....perfectly straight!
Just another 23.9 tonnes to go.
I'll add to this as other jobs come up.
