dobbslc
- Hertfordshire UK
My first real post about actual welding on the forum!
I'm having trouble with my tig welder HF start, it's an old Lincoln Norweld 131.
It's just not working when I try to start welding, I have to scratch start it every time and as I'm learning it's no good, I keep melting me tungsten......
It makes a ticking sound for about 5 seconds when I hit the pedel which I assume is the HF generator and a small component on the HF circuit board flickers a dull red while this is happening. I'm not sure if this is meant to flicker red or not. Photo below.
Once I've got an arc going ( assuming I don't bugger the tungsten ) I can actually product a reasonable weld....
Can anyone tell me how long an HF start strike should be? I'm holding the tip about 2-3 mm from the work. It's not jumping that, I'm not sure if it's me or the machine.
The flickering component it the white Siemens one in the centre.
