stevemon15
New Member
- Anglesey, North Wales
First off, apologies mods if this is in the wrong section, I wasn't sure where to post it.
I'm going to be making myself a simple welding bench, copying some of the ones I've seen on the internet. Basically it's going to be a box section frame, with bracing as appropriate, bottom shelf, and lengths of 10mm flatbar bolted on for the top, as it's cheaper than a 10mm sheet, and will allow access for clamping. Nothing fancy.
Bench is going to be 1m wide by about 500mm deep and about 800mm high.
I'm building to a budget, so I'm trying to price the materials as cheap as possible, but at the same time, I don't want to under build it. It's not going to hold any great weight or get the crap hammered out of it. I have a much scarred old wooden bench for that. I just want a clean flat place to weld.
So the question is, what's the minimum size box section I should be looking at? I'm thinking of 50x50x3mm should be the bare minimum, but if I can go smaller, then it'll be cheaper.
Any advice would be very much appreciated.
Ta.
Ta.
