DecK
- Kerry, Ireland
A few years ago, my old fella brought this back from one of his trips to England. He mounted a motor to the headstock and got it running and then stuck it to the back of the workshop and covered it with every bit of rubbish we could find.
With the bit of free time at Christmas I decided to have a look at it and was surprised with what I found. There doesn't seem to be any major play in any of it and for a lathe made in the early 1900's it seems to have a lot going for it. It has a power feed to the saddle and cross slide, forward and reverse feed to the saddle, I think I counted 4 chucks from around 6" up to what could be a 15". A mix of 4 jaw and a self centering 3 jaw.
It is a gap bed and I know the section for the gap is there somewhere. It also has a set of change gears up to 127 tooth but missing 2 of the smaller ones.
Now, I know nothing about lathes but the talk about them on here peaked my interest and caused me to have a look at it with the idea of moving it from it's current resting place to a workshop I'm building at the moment. The workshop wont be finished for a few weeks so the eventual move and hopeful restoration will be a few weeks (maybe months
) down the line.I've bought a dti and mag base this eve just to see if the chuck is running true as there is vibration through the lathe when its running but this could be down to the way the motor is positioned and a not too level surface. I'm hoping to remove the motor from where it is and make a frame that can be bolted to the wall and get a 3 phase motor to run off a VFD. I have tried before to turn stock on it but the results were terrible being honest and that put me off it but know now that there is more to it than just turning it on and running the tool along the stock.
So basically going into the unknown here. If anyone has any opinions on what to do or questions just ask.
There probably is a serial no. on it but its covered with a layer of grease and grime that's over the whole lathe. The plus side to that is that all the paintwork seems decent was you clean it off.
), or else I was born too late and there was no such thing as a machine shop there.
