Just because it's low amps doesn't mean there are not advantages to water cooling. A wp9 Tig torch is the nicest to manage yet limited to 120 amps. Everything about water cooling is nicer regardless of the current you use. Torches and consumable parts last longer, shrouds cool much quicker and a wp20 Tig torch is way nicer to flick about than a 17It's only a 160amp machine that, what do you want water cooling for?
I like half of that. I would never encourage a total loss system. Cost isn't the issue its just wasteful. Your right though a pump and a big bucket with a bit of piping and your away. Cheap cooler.Cooler can be nothing more than a pump and a tank... Or if you are on water rates just run it off the tapeven if you're on a meter, probably cheaper than buying a cooler...
As for a small tank, if you own a TIG set and can't knock one up you should be put against a wall and shot.![]()
Paul never mentioned blindfold. Just shot.I struggle to not get my tungsten stuck putting a bead on a flat plate- pass me the blindfold![]()
Seriously Paul, wrong vocation mate. I'm putting you in for laureate if you keep this up ^_^As for a small tank, if you own a TIG set and can't knock one up you should be put against a wall and shot.![]()
It was only to cover my shame from the state of my tig welding...Paul never mentioned blindfold. Just shot.
No need to be ashamed. You should see me with electrics. Red to red black to black and if I'm feeling lucky I might have a go with a green. We all have our strengths.It was only to cover my shame from the state of my tig welding...
