Maker
Most folk just call me; Orange Joe
- Keeler crater
I've got a 3 phase 415 volt motor that only has three connections so it can't be converted to 230 V by swapping linkages over. I've opened it up and found all 13 soldered connections in the windings:
Three connections are red-red wires, three are black-black, three are yellow-yellow, three are red/black/yellow-mains supply and 1 is red-black-yellow.
It's a 4 pole motor so I assume the connections with two wires are where two poles are connected in series and the one with three is the centre of the wye diagram below (Neutral?)?
Am I right in thinking that in order to wire it as delta for 230 volts I need to desolder the red-black-yellow connection and solder the red from this to the black mains connection, the black from the centre to the yellow mains connection and the yellow from the centre to the red mains connection and bring these three new connections out to the mains plate in the motor?
If none of that made sense I'll draw a diagram of what I mean.
