have you been on the briggs and Stratton web siteI am looking for a workshop manual for a briggs and stratton quantum xtl 55 engine from a lawnmower. I have googled it but cannot find much. Any lawnmower enthusiasts know where i might find a pdf ?
^^^^When did they go Chinese?, our mower is about 1997 and done about 600 hours without any problems.
I've worked on a few oldish Briggs & Stratton powered lawn mowers and the only common fault I've come across is the carb diaphragm (About £2) otherwise quite reliable.I am looking for a workshop manual for a briggs and stratton quantum xtl 55 engine from a lawnmower. I have googled it but cannot find much. Any lawnmower enthusiasts know where i might find a pdf ?
It definitely sounds like diaphragm symptoms, cheap and easy fix, make sure its fitted the right way upYeah thats why i was looking for a manual, when i used this mower years ago it used to hunt up and down the revs.
allways thought of briggs and stratton as the cheep option when not prepared to spend honda money.
they seem to do what they say on the tin but never seemed to run or start as nicely a a honda. all except the v twins seem to offer good service life. the v twins often end up with a hole in the side tho![]()
Damn, mine's a V-twin with about 600 hours run, how much longer have I got?
last one I had was well before this nonsense and they had the easy pull mechanism and ran for ever and a day we'll until the petrol ran out anyway
although I did see a few where the valve seat wore away closing up up the tappet clearance which in turn would stop them running easy fix was to grind a lump off the end of the valve stem
.....The mower i have is a jonsered......
