the adapor for using a standard chuck is fine as long as u dont use it on hammer . buy a decent make drill if its going to be used regular not a cheapyYou can get a standard chuck with an SDS shank on it to allow you to use normal bits, I don't know how good they are though.
Only regret with it is that it's a key-chuck rather than keyless. Not sure if you can get keyless ones.
I've also used it on chisel- only to remove some floor panels in my car. Worked a treat. Hard on the wrists!
the op was asking for a standard chuck and adaptor for fitting in to the sds drill chuck for drilling not on hammermy one is keyless.
ive not tried it on my car lol.
but ive used it many times to chisel up old floor tiles, channel out walls.
with a standard chuck in mine hammer won't operatethe adapor for using a standard chuck is fine as long as u dont use it on hammer . buy a decent make drill if its going to be used regular not a cheapy
Yes, I did. iPad autocorrect beat me.....Im guessing you mean Dewalt?
Ive found the 110v stuff to be a bit pansy, I use a makita 110 and a 240 and they both do 35mm holes in masonry, and a 36v Bosch for smaller stuff
