scotto75
- Bristol
Hi there,
I've recently changed my welder. Was originally using a Sureweld Monomig 101 but with little success on anything over 1.5mm. I now have a Clarke 100EN Turbo and have had to start over again with the settings using 2mm stuff. I've finally got the welder behaving, having replaced the wire liner, swan neck, tips, shroud, earth cable and clamp, but could use some pointers as to what I may be doing wrong or could do better.
The below pics are of a butt weld on 2mm steel. I had the power on the highest setting, 2 MAX, and started with the wire feed on 7, and run a few beads on the sheet as I lowered it until I got a nice sound. I ended up with a WFS of 3. I started on the right and pushed the weld using a slight angle to the right but with the neck 90 degrees to the work piece. The tip was a couple of mm inside the shroud, and the CO2 gas was set to 15lpm.
I have a few of questions....
1 - How does it look? Does it look like it's penetrating properly? I beat it pretty hard with a club hammer and it didn't break.
2 - When it was cooling, there was a pinging sound with little bits flying off. Is this normal? Not sure if the gas is too high and this is causing air bubbles?
3 - When I was welding I was getting a nice sizzle, but the sound would almost stop for a second every now and then. The weld and puddle didn't seem affected when the sound changed. What would this mean?
4 - I have been using a circular motion and was moving faster than I am used to. The weld looks a little wide. Should I try using 0.6mm wire on a lower setting, or is using 0.8mm on 2mm the best way to go?
Sorry for all the questions, but I am teaching myself and have no other place to go for advice. All constructive criticisms are welcome!
