.... and of course the standard ones are indeed indispensable sometimes because of their smaller size..If you leave the reg at 5lpm on both then yes your right no saving there. The idea is you can get the same coverage from a lens at a Lower flow rate. Ie you use a collet successfully at 5lpm and the weld is clean. Try a lens at 4lpm. Weld comes out clean??? If so you have just saved 20% of your gas usage simply because of the direct concentrated gas coverage over the pool created by the lens design. A collet body pushes the same volume out but through drilled holes at the side, it's then deflected off the cup walls and forced out in a fashion that is not controlled. The lens the gas is pushed straight down. It doesn't deflect off the hot cup it goes where you need it so less losses and you can drop flow rates.now tell me.... you are using a standard lens, and what flow are you at? 5lpm? than you switch to a gas lens and you are saying about savings... so again, what flow for the gas lens? again 5Lpm I suppose??... so where is the saving if the output at the regulator is the same.... doesn't make too much sense... I could agree with the better coverage at the same lpm values.. but savings??... I would doubt... I am using both... can't see much difference really....
Ditto. No lens and about 6lpm. Lens and drop to 4lpm.Spot on description Richard![]()
A
As I have done very little tig welding then what is the internal difference between the two?
