rusty69bus
moving to the goldcoast
- limbo
and they always require some modification
Read any series of article on car restoration and you'll see them replicating the original method when they replace a complete panel (spot(plug), seam or braize) and seam weld where they insert a patch repair.
If it's a covering or skin sill, it's classed as a patch repair and should be fully seam welded.
and I might also hide here
Yes Peter, that's how I read it too, in my opinion the manual clearly states that would be an acceptable method of repair. One criteria is that you have to remove the flange from the defective panel and spot/plug the patch to the existing inner sill flange.
Double worms I thinkand I might also hide here
cos I'm expecting this thread to raise a few hackles.![]()
No 'ackles ere mate, lifes too short. If you are replacing the whole sill section, i.e. the member as fitted in the factory (original) then it's ok to use the same method as the original constructor. If you cut a piece out of the sill, grind the spots off to the original flange, whatever, this is a "patch" repair, just like a skin sill (i.e. only a half of the original member) then it should be fully seam welded. VOSA's rules, not mine.
Don't forget that you can pass the MOT with a corroded hole thro' the sill, provided it falls outside the 30cm rule.
Also, someone earlier was on about "dodgy" tickets. The test gives a sort of guarantee. VOSA will hear complaints about mechanical defects for the first month, corrosion complaints will be considered for the first three months.
Anyone with a genuine complaint (in the time frame) should ask the issuing station for a VT17 appeal form..........watch their faces
Oh, & don't forget, loads of black underseal hides a multitude of sins![]()
I wasn't specifically meaning your hackles JB, this thread seems very much a grey area, it would be interesting to ring VOSA and see what their take is on it, mind you, I reckon even then you could probably speak to two different people and get two different answers.
When I was a tester ( a few years ago) we had a regular customer who'd bought a mini and thought the ticket might have been dodgy so he organised for the inspection to be done at our place. I've never seen anything like it, talk about fine-toothed comb! Mind you they didn't have to look hard to find the wodges of filler on top of recent newspapers and if I can recall correctly, they'd even filled over screwed up VT30's issued at the station who carried out the 'repairs' and issued the certificate.
. If you could get bits of MIG wire, spatter & birdsh*t welding out of a tube .........might just workDoes it depend on the panel? So that means when I replaced the wing panel could be an MOT failure,which was spot welded originally,and I have spot welded it again?
