Maker
Most folk just call me; Orange Joe
- Keeler crater
After all these months, I've finally sorted the Milling machine and had a little play
It still needs setting up some more, the head isn't perfectly perpendicular to the table, vice needs cleaning, probably new jaws, and aligning to the table and I need to get (or make) some proper Tee nuts as I'm using normal hex nuts right now which is I know is wrong but I just wanted to get going
This was with a 5/8" 4 flute end mill at 1700RPM taking a 50 thousandths cut. After this I tried climb milling with all the same settings and it worked very well too. I've also tried steel at 550RPM with similarly pleasing results
.It still needs setting up some more, the head isn't perfectly perpendicular to the table, vice needs cleaning, probably new jaws, and aligning to the table and I need to get (or make) some proper Tee nuts as I'm using normal hex nuts right now which is I know is wrong but I just wanted to get going
.This was with a 5/8" 4 flute end mill at 1700RPM taking a 50 thousandths cut. After this I tried climb milling with all the same settings and it worked very well too. I've also tried steel at 550RPM with similarly pleasing results
. I still haven't gotten round to painting the floor where it stood before Brewdexta moved it at Easter
