plan is too cut off the 2 parts that join the tanks together and weld caps, in my case i will be probably be using some 3-5mm steel plate. then after thats welded on i will be welding a nut on for fittings.
tank will need to hold 135 PSI. my only concern is one of the welds braking and shooting me in the head
i have a tig welder cabable of 200amps. stick welder capable of 160amps and a mig capable of 125amps. i would say i am best with the tig
EDIT- probably should have said the tanks will be going into my car and run of a 12V compressor for when im our 4wding.
