Fintray
- Aberdeenshire (UK)
Not trying to be heartless but he had 2 close calls before the fatal incident.id put a fair bit of the blame on his shoulders
Yes i agree with you,but there is a responsibility on both the employer and the employee to have a safe working environment.Yes, but if you are in a culture where dangerous things are being done, which can usually be gotten away with, it's easy to fit in with it.
It really has to be the company's responsibility to change that and ensure the law is complied with. Allowing machines to be used without guards, allowing machines to be used unsafely, not recording accidents, apparently no attempt to investigate previous accidents and correct problems. Training? Safety awareness? That company appears to have been caught with its pants down, not even making an effort.
Now I know H&S can be taken to extremes and to the extent that nothing could happen, but on the face of it, this case looks totally blatant.
The company should have had a Safe System of Work.Not trying to be heartless but he had 2 close calls before the fatal incident.id put a fair bit of the blame on his shoulders
He isnt at fault more than the company,but fool me once....
I'm a fan of the American programme "American hot rod " Boyd Coddingtons business. I much admire the workers skill, not too keen on some of the final products but some of their work practices are certainly dubious on a Health & Safety level. The workers are often portrayed slitting steel sheet using an air die grinder with an unguarded cutting disc attached. Wonder how many disc disintegrations they experienced.From the article:
"In addition the disk was rated for 6650 rpm but the grinder was running at 12,000 rpm.
The grinder had no guard so as it exploded, the pieces were forcibly expelled across the bay, one ending up some ten metres away."
Using a disc at about twice its rated speed and having no guard as well, is just asking for trouble.
Looking through the list of previous incidents with grinders which the inspectors uncovered, but which the company hadn't troubled to record, the company must have had a slapdash attitude to safety for a long time.
yea and welding hiding behind the shroud..ok we all do it to tack once in a while but those guys go for it.I'm a fan of the American programme "American hot rod " Boyd Coddingtons business. I much admire the workers skill, not too keen on some of the final products but some of their work practices are certainly dubious on a Health & Safety level. The workers are often portrayed slitting steel sheet using an air die grinder with an unguarded cutting disc attached. Wonder how many disc disintegrations they experienced.
RonA
