Hello guys, i'm a model engineer / hobby clockmaker with no experience in welding. It's always been something I wanted to try. An engineering pal gave me a SIP140 and I'm struggling like hell.
Just pinched this pic of the web but mine is identical.
Firstly, people on here talk about setting the current but this isn't displayed on my machine. There is simply a min and max rotator to set the current. It doesn't even have end stops and spins in both directions continiuosly so I'm not even sure what is max and what is min. Is there any setup I can hook up to measure the current and display it?
I had a perminantly dark hand held mask and I've just ordered a auto darkening mask - I'm sure having two hands on the rod will help.
The rods I've purchased are ESAB 2.5mm 70-100A , E6013. - I totally admit I didn't know what I was asking for and just went into my local engineers supplies, told them my story and they gave me these. Are these ok?
Also, is this an AC only machine?
I also have another issue in that my workshop has a small consumer unit as does my main house consumer unit to power the workshop. The main consumer unit in the house has a 40amp fuse feeding the garage but obviously this is not the switch that is tripping. It's the switch on the consumer unit in the workshop linked to that socket. I'm guessing this is a lower max current but it's partly hidden so I need to find that out properly - can anyone suggest what ampage trip switch should be running the sockets that I'm going to plug the welder into? Would you go as far as to give it its own higher rated socket and trip?
Great forum and any help or advice you can give me on my setup would be greatly received. My hobbies are all on my web diary www.raynerd.co.uk - it certainly isn't a showcase, mistake are shown and all!
Thanks in advance
Chris
Thanks in advance
Chris
