They did when I was a lad but they tended to be on the larger lathes.Just out of curiosity, do/did they make lathes with powerfeed on the compound slide? It seems kinda pointless but I'd always thought power crossfeed was pointless until reading this.
but thats the modern way of thinking apparently and anything less is derided as stupid in certain circles. Abuse your machine as long as it gets the job done.
Very niceI am not sure I see the point of a powered tailstock spindle, lever or capstan type arrangements would do the trick.
However, having looked at http://www.lathes.co.uk/cazeneuve360/ I definitely want one. It appears to be a very well considered lathe.
?Just a safer, more controlled way of feeding MT3/4 drills?
. One of my favourites on there is the Harrington (and not just because that's my surname)
. Oliver make a similar one too
.Very nice.
I must not be the only one who browses random pages on that site. One of my favourites on there is the Harrington (and not just because that's my surname)
to sit here a while longer.My name's Adam, not OliWey Eye young Oli Harrington, Your birthday is the day before mine, albeit a few years later.
I have an old Ginger Beer bottle, pottery, with my surname on and it means something to do with 'sugar refinery' in Portuguese.
I do not do random, I prefer the considered A B C approach, do not miss a thing.
Edit, now I have looked at Harrington and Oliver. Loving the Oliver 'sometimes gap beds' and the Harringtons are just huge but with the clever outrigger bits.
All clever stuff, and another reasonto sit here a while longer.
.Where are those made then, Looks like a good bit of kit.I am not sure I see the point of a powered tailstock spindle, lever or capstan type arrangements would do the trick.
Not sure about lathes but when I left the game in the early 70s we had 2 Churchill froriep vertical borers that were able to speed up as the cutting tool neared the centre.My name's Adam, not Oli.
I see what you mean about the ABC approach but links you've clicked before are a different colour so I still don't miss any.
Just had a thought about those big lathes; if you're facing a big part, as you feed the tool closer to the centre, the cutting speed will decrease, did they ever make some kind of special automatic gearbox to speed up the spindle as the tool gets closer to the centre to keep the surface speed the same?
Wow, just googled thatChurchill froriep vertical borers
, it's like a vertical spindled lathe, what a beast
.You could probably wire a DRO scale on the cross slide to a VFD to do it automatically.thats where an inverter speed control drive would come in handy turn it up as u get nearer the center
You get the speed advantages but can turn between centres still on the same machine when the occasion demands. Plus imagine being the poor sod on the hbx590 or hb700 with its 2m long bedway and having a job that involves dragging the tailstuck up and down the ways all day.I am not sure I see the point of a powered tailstock spindle, lever or capstan type arrangements would do the trick.
