mark williams
- Wrexham
If the crack in the alloy is vee d out both sides and cleaned really well would my 210 amp machine weld it ok? Is it ok to pre heat with propane?
Use a 5556a rod and will be ok when welded and about 140 amps will be more than enoughIf the crack in the alloy is vee d out both sides and cleaned really well would my 210 amp machine weld it ok? Is it ok to pre heat with propane?
That's an exact 5.3% mg. without knowing the composition of the wheel what made you select that one. I believe and correct me if I'm wrong a lot of alloy wheels have different compositions and it's not quite that straight forward. I'm not clued up on exactly what they are made of so I am open to criticism if it is that straight forward.Use a 5556a rod and will be ok when welded and about 140 amps will be more than enough
That is just up the road and I am very much into my bikes. That's worth noting those details down as I wouldn't repair them my self if they become damaged. Cheers.Roy Thersby have been doing it for a million years, sort of. They now have a facility in St Neots as well as the original shop in Stockton.
Worth a look Richard since you are not far.
has he got some sort of weld coding for doing them for motorspot? similar thing to me welding aircraft parts in work, they then get a caa aprovalBloke just outside Scunthorpe, Forge Welding in Normanby, does it for Motorsport.
They come with a certificate of conformity or something or other for motorsport, but he cannot supply any certification for use on a road vehicle sadly.
I don't see the difference mate. Truck, car, bike or can if it goes wrong it can end in catastrophe. Truck wheels are relatively lower risk as they are steel so you know what your playing with and steel is much more forgiving. I'm not been negative but there is no shame in leaving that to the guys that do it day in day out.I would never repair a motorbike wheel or truck wheel.
Are they? I thought most of em were steel. Live n learn.when was the last time you looked at truck wheels lots alloy to keep the weight down trailers as well
http://www.tyretracks.co.uk/
