how hard is it to melt ali to make castings?
want to make some odd sized step pulleys for a little project.
would make a block then turn it down on lathe.
what equipment would i need?
biggest pulley would be 10" smallest 3".
I've cast step pulleys, in fact they are the reason I got into it in the first place. They will need finish machining on a lathe, and they can be a pain to balance. I did mine a mostly solid, which is easier to make a pattern for, and is more tolerant of less than ideal sand. The additional mass also smooths out drive pulses, which may or may not be worth while for you. My setup is a 25l oil drum lined with refractory, and runs off propane and a hair dryer.
There's a bunch of pics of my setup and some castings here
http://s10.photobucket.com/user/Gar...3&page=1&_suid=142048411879604335661191409559
I found ali casting easy IF YOU LIKE VOIDS and UNEXPECTED changes under the visible surface. Why cast when you still need to machine and for parts that can be bought off the shelf or bought and adapted most likely. Not saying it cant be perfected at home but better to fight only the battles you have to fight and win them all
possibly for a 2" single pulley, but if you're wanting a 6-4-2 step pulley (or whatever combination you like), that's a BIG chunk of bar to turn down for the smaller diameter - and VERY expensive to source ready made.These pulleys sound quite basic surely just turning them up on a lathe from a solid bar/block would be far less hassle and time consuming and produce a far strong finished item to boot?
If it's done "lost foam", the pattern can be made on a drill press, and the cast pulley can be finished by hand - IF it needs it (usually cut off the sprue with a hacksaw, file smooth, then a quick sand)
I've made lost foam pulleys with extruded polystyrene where the shape of the little white balls are evident (which gives an idea of the level of detail which is possible) - I've done "lost wax" casting of a hand where the fingerprints can be seen.
Dipping the lost foam pattern in melted wax for a smooth surface, then a thin shell of plaster of paris before casting can produce a "finished" article (except for the sprues) straight from the sand.
S'pose it depends if you're a machinist or a founder?
