This is just an idea before you all tell me I should not as it's dangerous! But, if I made a box/cube out of 2mm steel and each edge was say 4 inch long, in one flat drilled a hole and welded a flat nut or flange so I could stick water in to it and pressurize it, what would be a good safe pressure to test that the welds were OK. How does one work it out?
I am not talking a 1,000 psi here as I think 2 mm wall would have ruptured well before with three faces trying to lull the corners apart, but say would 50 or 60 psi water pressure, be OK.
If you are doing fuel tanks say diesel or petrol, expansion tanks in vehicles etc. how would you test them?
Or do I have it wrong and do you pressurize with say 20 psi air with a gauge on and check an hour later for leaks?
Adrian
Adrian
