I have a Karcher Washer similiar if not the same as the one you pictured, what do I need to set up a Wet Sand Blasting system, I need to do some Wheel Rims?See this,the lances are interchangable with a wider variety to suit different jobs.
)I have a Karcher Washer similiar if not the same as the one you pictured, what do I need to set up a Wet Sand Blasting system, I need to do some Wheel Rims?
A big set of water proofs for a start (sou'wester)
Good man well I have emailed the sell of the blasting kits asking what karcher I need to buy for the use of his blasting kits .
He tells me that nilfisk is very good pressure washer but needs to be 150bar with 8ltr/m just looking at them on ebay £399![]()
i just run a bit of water mixed with antifreeze in to my power washer over winterIf I recall someone did post a warning about storing your pressure washer wit water left in it as it can freeze over winter damaging the pump. So drain if you can.
