ben8vgte
- Bedfordshire UK
Hey all,
I just got a Mosa MSG 201 s sold as working, but seems to be faulty yes I will be taking it up with the seller but would rather fix it if possible. So engine side runs and starts perfectly, but the electrical side has the fault. It does not auto accelerate when you strike an arc, the weld button is pushed in and I have moved the power lever about as well. It does make a little spark as you try to strike, if you manually rev it up it does weld. The 110v has the same fault, but oddly if you rev it manually it does not run a grinder unless to burn a rod at the same time.
I thought it should be one or the other and the push pull selector switches?? Any help or pointers would be great thanks..
Mosa msg201s
Mosa msg201s
Mosa msg201s
Mosa msg201s
