Not heard of the acetone wash before. I will give it a try, but I usually pickle it for an hour with an acid mix.That leaves a light matt finish, then some compound on a cotton wheel. I prefere the brush look as it is less trouble. (=lazy)
Just looked at the flask: 4% Hydroflourique, 20% nitric acid. Not sure about the rest, there is a thickening agent so it doesn't flow off so easily.What is the mix that you use?
When I used to work in the steel industry we made stainless steel plates, big ones, an inch thick and 15 feet wide. The machines we used to polish the sheets used "scotchbrite" pads.
when prepping like that.
Kemppi -I noticed my supermarché sells small packs of citric acid powder, and larger packs are sold in my local Leroy Merlin-not sure if your locals will do the same.
Not really done anything with citric acid myself but saw chunkolini uses it quite a lot- so mentioned for info in case its of use to you.
As a long time and bulk user of citric acid I'm surprised to see it being used in this context. For the best price on larger quantities it can be found in almost any home brew shop where it's used for a variety of purposes in brewing wines, beers & ciders. In packets of a kilo or so it comes in useful for other things in life:
As an organic acid it has little effect on most pure metals other than (maybe) zinc or whatever metal is used to electroplate the elements in cheap kettles as an alternative to chrome. Meanwhile it is quite happy to gobble up most metallic salts.
- 250-500 grams added to the cooling system of a car can dissolve most blockages overnight and more if left in for a day or three while you drive around in it before flushing and replacing the old coolant with fresh (keep an eye on the coolant level as it can drop drastically if it opens up previously blocked waterways).
- A heaped teaspoon in a kettle will remove all the limescale that's built up inside it. Rinse 2 or 3 times afterwards to remove the residue.
- Old copper or brass ornaments can be brought back to 'as new' if soaked in a boiling solution for a while.
- Stains inside a toilet bowl will succumb to its tender embraces if you 'plunge' out all the water, drop in a heaped tablespoon and follow up with a kettle of freshly boiled water. Leave as log as possible and just flush as normal.
- Add to drinks or foodstuffs according to taste to add an extra tartness to them. Why not? It's on the list of ingredients on many of them already eg. crisps.
