I asked this yesturday on the Tools forum and didn't get the answers I wanted and then I noticed there is a specific forum for "Air Tools" so wonder if I could try again.
I want an air powered sander, which uses cheap, readily available discs, which I can use to 'grind' edges/surfaces (i.e preparing metal before welding).
I don't think I want an 'orbital' sander, as I assume these are more designed for things like paintwork.. I want something which just rotates at speed and holds a pad.
Looking at eBay and can see lots of sanders, but they either have a large central collar which would make it impossible to use the flat surface of a disk.. Or they are orbital..
Does anyone have any suggestions about what I should look for? Ideally it would be nice to get an orbital sander on which you can turn the orbiting mechanism off.. Some of the listings imply that this is the case, but none say it directly... Hence my question.
Jon
Jon
