not so much an advantage but a must in a latheCentre drills, are they really an advantage.?
the only advantage if u didnt need one would be time on changing itGo for the long series type cos when you centre with a standard length centre then remove from chuck you may find you have to release the table of your pillar drill to drop enough to get drill to slip into chuck thus loosing position from your centre drilling.
A stub drill is the proper tool - centre drills are for drilling centres. For your small flexible drills, use a punch mark to stop them wandering.
using a carbide tipped drill after putting a center drill in 1st will probably make the tipped drill snatch and chip the tips why do u need a carbide drill on the stainless a good hss drill will cope at the right speed and a good constant feed using coolantReading wiki, it says you shouldn't use a centre drill before a carbide tipped drill. I need to drill lots of 7.5mm holes in stainless on my small capstan, now I'm confused!
