dutchman
t(r)igger happy
I’ve been reading the manual for my new 2nd hand tig welder and it states the following:
Electrical conductors within 50 ft (15.2m) of the
welder should be enclosed in grounded rigid metallic
conduit or equivalent shielding, wherever possible.
Flexible metallic conduit is generally not suitable.
This is to reduce HF interference.
I have a large metal cupboard (6 foot high) located 1m away from the workbench. Does this mean I need to ground it with a non-flexible bar? I dont't see why a cable wouldn't do it.
Is HF interference really a big problem, also when welding 1.5mm steel (at low amperage)?
) HF is used all the time when welding on AC mode. This is because the machine cannot switch from positive to negative quick enough and the arc wants to extinguish at the zero point. A HF overlay is used to keep the arc going when it passes from positive to Negative and thru the zero point.
