ben8vgte
- Bedfordshire UK
After owning many rusty astra's i thought i'd rebuild on fully as a trackday toy.
It's amazing how many rusty you hole's you find
Wish i could turn my car into out and out track car, the girl friend would moan far to much though
Dont mind at all![]()
On the back of engine just above the water pump outlet there's a blanking plug in the oil gallery i'll take the feed from there and weld a return into the sump, it's a kkk k-14 turbo off a 2.8 iveco daily, I'm not after too many ponies (180-190) i'm more interested in a responcive engine so i'm keep the pipe work short by making a charge cooler over the gearbox and a new inlet manifold with the throttle body on the other side.
Tis very true my old car was totaly stripped as well no sound deadning, can be a bit much on long runsyou wouldn't be able to hear her once your flying round the track.
i think you will be better off putting a front mount on there than one over the gearbox. it will lower the charge temps so much more and will equal more responce/power. unless you want the turbo conversion to remain a secret from the outside of course!!
are you doing any internal work
Not sure on the size of the turbo, when are you expecting it to be fully spooled? And whats your rev limit going to be?
I'm not spending too much on the engine internaly to start with to see what happens.
