welcome to the forum hope your not wanting to arc weld cars
some people want to learn to arc weld on cars and its hard enough if you can already weld
mig is plenty good enough for cars, welcome to the forum mate there is now a growing number of members from ireland. are you recommending to each other!?!?
blatent plugYea heard of here from forum4farming.com
a bit slower maybe dont be afraid to push that rod in to the weld when i started the rod kept buring back and it wasnt a even weld bead
i used to when i started touch the metal then lift it ever so slightly to the other side of the weld pool and touch it again and kept doing that this kept the rod close to the weld and then when i got better i did not touch the metal but kept the rod nearly in the weld pool.
thats what they told me when i started those welds look alot better than mine the first time i welded. have you tryed the fillet joint yet took me a long time to become good at it but the secret is a tight arc if not on a fillet you will get weld on one side and none on the other but a loud of slag that used to make me so angry![]()
