wayne 4908
Hi anybody no how much it would cost to have the transformer rewound on these welders?Thanks
) or you could unroll it and measure it either way this will give you a length or weight of wire to order.
. If you have a sheet of paper to hand when un/rewinding to note down turns then when you get interupted or have to form loop you can jot down number. Main thing is to keep windings nice and tight (if you looked at the link from the other chaps rewind, note the handle length he used!) Use a bundgy strap or similar to keep from unwinding while you go for a pee!! ect cos as soon as you start bet youll need to
There are vids on youtube on how to strip a transformer, think most are from geeks wanting to have piles of steel/iron core and copper wire material.....
Look for "MANUAL transformer REwinding"
bit more than 13 amp
but only takes a bit to rub off and short to fail so then went with the new wire ect. I did manage to rewrap the secondary (thicker wire) with some better ptfe tape as that would have been expensive to replace ( about 4 or so mm) and yes before any one points it out it is an aluminium secondary. Had to reaneal secondary to soften to allow rewinding but you won't have that problem with seprate secondarys
