T.E.D. Jordan
I'm not sure if this is the right section, but I'd assume so.
I recently got my welder up and running and its welds perfect....when it doesnt trip the breaker.
Its 220amp welder (Lincoln Electric) and It uses a 32amp 240v plug. I installed an appropriate socket by teeing off the ring main in my workshop, which has a 32amp breaker at the box, no more than 10 metres away at the main feed to the building.
When I weld it depends what I do, but if i say, tack a piece in position first then go to weld, it will 30% of the time, trip the breaker (about setting 4 of 6 power-wise on the welder, more-so maybe on the higher settings) 30% weld itself to the nib and trip mid-weld after a few inches and 30% never be a problem.
Any suggestions as to what I've got wrong here as aside the welder I've never had a problem with electrics in the workshop and the wiring is maybe only 4 years old.
Is my breaker box too low a rating? Or can someone suggest another cause?
Jordan
Jordan
but dare i say just upgrade the cable and circuit breaker to 40 amp and stick with the 30 amp plug without getting shot down in flames by the do it by the book squad
because thats all i would do even if it isnt by the book. it will never cause any problem or overheat
