steve.h
Fire Starter,,,,
- swindon sn4
Evening all.
So I am trying to get my little forge running right. my current forge also doubles up as a fire pit for camping, its 40cm x 40cm and 12 cm deep, untill I have more funds this will have to do, I do intend to build a purpose built forge when funds allow. I have tried running it with my 2hp compressor, but even at full throttle the air delivery would only get my piece of 4mm an orange colour, bendable but I want to weld with it.
I have a 5" inline cenrifugal fan that does 225 M3 so that works out at 133 cfm, I read that if you reduce the pipe from the 5" to say 2" then this will increase the pressure of the airflow as well, So can anyone tell me if this is correct and also will I loose any cfm because of the reduction.
Would the 5" with reduction run my little forge hot enough to weld with (and my next forge of around 60cm X 90cm), so far I have only run it with wood, so burning down to charcoal and also adding some bagged charcoal to it. I do intend to buy a couple of sacks of coal, but not sure what to buy, do I use smokeless as this would help with keeping the smoke down and happy neighbours ??
I am loving what im doing so far but will be much happier when I feel like im going to melt stood infront of it.
Thanks for your input as ever.
Steve.H
Steve.H
