fuff66uk
I have a Clarke shhh silent compressor the same as the one in the pic,the copper pipe that comes out of the compressor part has split due to someone getting too heavy handed with the compression joint.
My question is can i braze the split to repair it as there isn't enough pipe to simply cut it off and then refit the joint or would another method be better ? If brazing would be ok can you recommend a rod to use as i have never done any brazing?
Thanks
Al
Thanks
Al
