Hi,
Im wondering if anyone could point me in the right direction as to which blast media would be best used on alloy wheels.
Really looking at blasting for 2 different tasks,
one is to give a light quick key to the wheel which would be suffient for directly painting/lacquer the wheel, this is mainly to speed up the keying up stage on multi spoke alloy with no or minimal damage?
Second use is to use something aggressive enough to stip back flaky paint and corrosion.
I currently use ali oxide in 120grit to help speed things along but is too aggresive for just direct paint but seems suitable for primer
Thanks in advance
Thanks in advance
.....i see you can get an attachment for powerwashers now,not sure if they work well though?
.....no risk of silicosis with it in water?.....you also remove the need for a larger compressor
