Stickmaister
- Gwynedd, Wales
Hi everyone ,
I'm here to ask for some expert advice, I'm doing a job for an old friend. A garden water feature..
He wants a stainless steel sheet, made into a sort of trough, that will have water pumped into it. The water will then flow through the trough and out of an opening the other end and drop into a pond.
Here are some photos to help me explain..
The slate slabs will be removed from the concrete walls and the trough will sit on top of the walls. (walls 100mm thick at the top) 1700mm width overall
Here's a simple sketch.
Two main questions I have and what I need help with is..
-What thickness sheet can we get away with? Bearing in mind I would like the sides folded. we were guessing around 4mm? Would that be strong enough without bowing? The water should just flow through the trough and not be held in there.
I would like to avoid welding any strengtheners , would like it just a folded sheet.
- Is it possible to get a single sheet this size? And have it folded?
Here are more drawings and dimensions..
I would like to avoid welding on this as much as possible due to only having a mig welder and although I can weld stainless there not the cleanest welds.
If there isn't a sheet size big enough it will have to be welded together and I'll have to figure out the best way around that.
Obviously there are areas that will need welding and I hope I can dress the welds down nicely. I'm concerned about distortion and rusting on the welds.
Many thanks for your time if you've read this and any advice will be much appreciated.
Thank you,
Thank you,
