Red'n'Black
- Malvern, Worcs
By 'modern' I mean pretty much anything built this century, with an electronic throttle body.
With old cars it was simple, screw adaptor in, foot to the floor and turn the key. But with modern stuff, every time I've looked at live data the throttle position only seems to be vaguely related to the pedal, running or stopped. Plus I'm never sure if I'm going to damage anything by cranking it with the ECU powered up but the coil packs disconnected.
My last car, a 2006 Saab, I used to do the test with the key out and everything else powered down. The return spring was set up so that it was about a quarter open at rest, so I just bridged the starter relay with a wire and I was away.
Everything I've owned since, including the current gen 4 Legacy, the throttle is sprung towards fully closed. I expect professional-grade scan tools have a 'WOT mode' or similar for this situation, but is there an alternative method a bit more in the DIY-er's budget?
One idea I had was to unplug the throttle from the loom and feed a small current into the motor terminals, just enough to hold it fully open against the spring.
Any other suggestions welcome.
