Bluemotion
- Holmfirth
I’ve a Thermal Arc 202 AC/DC tig with a multifunction torch ( no foot pedal) which I’ve had for many years. It’s not my main welder as I normally use a MIG.
The problem I have is that I’ve never successfully used the tig to tack weld sheet steel as I can’t find a way to do it. I’m guessing to do it it needs to be on 2T but it never releases power once I press the trigger and won’t turn off after trigger release so I have to pull it away from what I’m welding and leave a mess. Also I’ve never been able to manually pulse weld either. This has been like this from day one of it being new. Is it me or the equipment?
Most of my work with it has been alloy cast repairs so I’ve not really needed to do thin sheet steel.
