If the pumps dry up it'll be like the zombie apocalypse when the Amazon/Courier vans stop running.I mean seriously if the pumps ever did dry up and it was a choice of working or not working then i would have no issues at all in getting to work on the red stuff and winging it.
so true LIf the pumps dry up it'll be like the zombie apocalypse when the Amazon/Courier vans stop running.![]()
Except there'll be loads of smug EV drivers whining back and forth between the conked out ICE vehiclesIf the pumps dry up it'll be like the zombie apocalypse when the Amazon/Courier vans stop running.![]()
EVs have their place, but that's the 'last mile' thing. The HGVs that trunk the goods to the distribution warehouses are all diesel, and there are a lot of them.Except there'll be loads of smug EV drivers whining back and forth between the conked out ICE vehicles![]()
Until they have to use the diesel generator powered charging points ............Except there'll be loads of smug EV drivers whining back and forth between the conked out ICE vehicles![]()
I've often thought that if the powers that be really were serious about cleaning up transport they'd open up the canal network to commercial boats and make them electric. A canal barge would be ideal to convert given what they do and that they're never more than a stone's throw from a grid connection.
And the canal boats could probably have a large flat roof filled with PV panels as well.
Clearly not enough for complete powering, but range extending somewhat.
My vessel 62’ narrow boat.Boats are a very efficient way of moving things.
Quick google gives you the numbers - "Traditionally, a single horse was sufficient to tow fully laden narrowboats, often pulling 50+ tons at walking pace. While 1hp is the technical equivalent, a horse can exert up to 15hp in short bursts, making it more effective than a 1hp motor. Modern narrowboats typically use 30-60hp diesel engines, although only 2-5hp is needed for canal speeds."
But when you think about it - a fully ladened 44 ton lorry and trailer - can get near 8-10 mpg now - which I think is good compared to a 1.8 ish ton car that does 40-60 mpg - (that is English gallons @Erie Fred )
Last wade ( how do you spell that ) was around 28 ton.
She has a 1920s motor that was 12hp at 500rpm when new.
I have to think I need to stop about half an hour before I need to stop…..
And it uses around 1.5 gallon for 8 hours chugging.
I thought this too...
Don't need many horse power per ton either for a heavy barge - plenty of access to the power grid - new purpose made canals would render themselves to driverless boats as well...
But that would take planning - forward thinking and money. You only gotta look at the recent "fast train north" disaster.
We had a train network... But it got closed.
"The Beeching cuts, initiated by Dr. Richard Beeching’s 1963 report "The Reshaping of British Railways," led to the closure of roughly one-third of the UK rail network, including 5,000 miles of track and over 2,300 stations, to reduce mounting financial losses."
I thought this too...I saw a pic of queues in the news at Costco...but Costco is often busy I think.its almost like they want to cause the problem!!
The only subject i agree about a news blackout is fuel, its only panic buying that runs the pumps dry.We were all talking about this last night, and someone pointed out that a few news channels that seem to thrive on mindless drama, had been doing news slots on cars queueing. its almost like they want to cause the problem!!
Go past 3 fuel stations in town on way to work, they have gone up by few pence, but no queues
Costco always have fuel station queues on a Monday, Friday and for a couple of days after payday - busiest time is 1600-1800 and the quietest is 0630 - 0830 on a SaturdayI thought this too...I saw a pic of queues in the news at Costco...but Costco is often busy I think.
Need to fill the van up...I'm up t'north at the minute and seems cheaper up here.
Distribution, a lot of canals in the uk run along side railways and motorways.The problem with canals and rail is that they only go to limited places, so you still need to load onto lorries at either end which means triple handling every item which is ridiculously inefficient.
As a nation that's surrounded by the sea you'd be better off putting stuff on insore boats to move it around the coast than trying to dig thousands of miles of canals through people's back yards. It'll get you as close as a canal will but at zero cost.
