Bryan Williams
- Manchester England
Hi, hoping for a bit of advice on the above..
My daughter son in law and baby have been in her first house now since November and recently noticed the membrane in the loft is glistening with tears of condensation..
It's a 70s 3 bed semi a frame ,her father in law boarded it out with osb right down the middle from end to end lifted on I think 4 by 2.
They've filled that with camping gear and assorted junk..
It wasn't showing any sign off condensation when they had it surveyed but it had been a single girl living there, didn't have the heating on much..they are hammering it a bit ..a lot of cooking showering usual baby care washing..
I had a look today, outside they have the soffit area boxed in front and back, no vents..
They have what looks like original ridge tile vents, narrow slitted type about 2ft in from each end of ridge.
In the loft they have what looks like three different layers of insulation.
A bottom layer of white cotton wool ball looking stuff..a 3 to 4 inch layer of rock wool type stuff and a thicker maybe 8 to 10 inch newer looking layer.
The middle insulation is now under the boarding end to end to the first down struts..behind these struts going out towards the sides the thick insulation stops about ten foot out, then there's the thinner layer of insulation for about 5 to six ft then a couple of ft of the cotton wool stuff..
On the gable end there is a square cut out of the membrane underneath the ridge tile vent..
At the other end there's no hole cut into the membrane
My thoughts for what it's worth is they would need a row of vent holes cut underneath the soffit area boxing with the plastic grills popped in ,front and back.
A hole cut for the ridge vent although they don't look man enough to give good ventilation.. I'm wondering if a couple more modern vents would help
As regards the insulation, where its the newer stuff it looks OK thick enough no gaps , but it's been flattened with the boarded down the middle and I've no idea if it(the new thicker insulation) should go right up to the outer edge just stopping where the soffet vents should be..
The timber all looks in good order
any advice would be appreciated,cheers
However, warm air rises, so may be stuck in the dead air near the ridge, so maybe ridge vents are the answer ?
