Sounds about right. We used to add 2 stroke into the tank on earlier RX variants … probably along the same lines. Also I’m not sure anyone running a rotary is thinking about emissions too hard - Mazda should have got an exemption against the rules simply because they are cool !in 2001 ish the design of the mazda rx8 was nearing completion. the designers were tasked in formulating a specification for the oil. after a rather long period of research and development the engineers decided on a mineral 10w40. 15w 40 in warmer climates. this was passed to the higher ups in mazda, who kicked it back, and said no, emissions are affected by such a thick oil, do better.
mazda finally settled on 5w40. the result of which the primary failure mode on correctly serviced cars was rear stationary bearing failure (this is discounting cars what had early failure because of abuse and neglect)
otoh, most specialists, myself included, and most engine builders specify 10w40, as the original engineers did. i have seen engines that have been run on 10w40 go 140k miles with no appreciable bearing wear. go figure.
Most turbo engines with stop start have water cooled turbos with an electric pump that runs on after the engine has stopped.I’ve always hated stop/start, especially on turbocharged engines. Whoever thought that was a good idea? Car on a drive, up to temperature, turbo working away merrily, and then you come to a junction. The engine stops and oil pressure is lost. Such a nice way to treat a turbocharger, don’t you think?
Oil isn’t just lubricating the turbo, it’s cooling it as well so you get burnt oil accumulating in the turbocharger oil ways.
I just map it out. Button does nothing, problem solved.
As for other engine component life, there are so many problems which oil can’t fix. Manufacturing tolerances, the fad for tabless bearing shells, small sump capacities, long oil change intervals, weak timing chains, wet belts, and cheap oil filters to name but a few.
And as for this “Long-Life” oil, Pah! That just means the additives should keep it in spec for longer, it does not mean the oil is somehow miraculously staying clean. It’s still picking up all the junk and carrying it around the engine for longer causing more premature wear. Evidence of this is plentiful in the USA where bypass oil filter kits are quite common, and where they are fitted, it’s not unusual to see 500k miles with little discernible wear.
But the oil pressure goes to zero when the engine is stopped and takes a second to rise when the engine is re-started, that’s when most of the bearing wear takes place.Most turbo engines with stop start have water cooled turbos with an electric pump that runs on after the engine has stopped.
If its a generator small engine, it's not likely to be anything exotic - probably an ordinary mineral oil.Neither the generator handbook or the engine handbook give a spec, just "use 15W-40 oil"![]()
Early and older cars didn’t even have oil filters. Manufacturing tolerances could be measured with a yardstick and it was all done by operators, hence the huge discrepancies.Considering the general trend towards engine reliability and longevity alongside performance, economy and cost, I wouldn't be too quick to knock engine development.
Early road vehicles were expected to see oil changes every few hundred miles with a lifespan of a few 10s of thousands of miles. All while giving performance of 10s of bhp/l
Mid century cars had improved on that with better performance, service intervals measured in 1000s of miles and engines built with relatively simple rebuilds in mind at several 10s of thousands.
Early 2000s cars saw service intervals often exceeding the lifespan of the first combustion engined vehicles often with engines outliving the rest of the car at ~200,000mi all while delivering 150+bhp/l
Very modern engine designers appear to be struggling to make recent developments reliable under real world conditions. But I suspect that the overall trend of improvements will be followed in the end.
I do keep an eye on the hour meter for oil changes, the previous genny was 100 hour intervals and did over 700 hours before the electronics died, I will try the 50 hour changes on this oneIf its a generator small engine, it's not likely to be anything exotic - probably an ordinary mineral oil.
It'll bring a very small amount and an air-cooled engine? If so the oil gets a hard time (& the motor spins up instantly to relatively high rpms on most).
3000rpm? Oil change at 100 hour intervals max I expect, but change at 50-hours better.
They use 5W40, instead of the recommended 5W30 (or, 5W-‘dumbass’, as they call itLR Time on YouTube are advocates of 10/40 in Discovery 3 and 4s
)They use 5W40, instead of the recommended 5W30 (or, 5W-‘dumbass’, as they call it)
He’s kept the big end bearings from all the rebuilds, with details recorded on them, and it does seem that the 5W40 engines have less wear. Small sample size, though.
I was thinking of upping the oil viscosity for the wife’s petrol V40 from 0W20. Wasn’t sure which number to increase. Perhaps better to change the oil twice yearly instead of once?
What genset engine is it? Chinesium or not? Petrol or diesel?I do keep an eye on the hour meter for oil changes, the previous genny was 100 hour intervals and did over 700 hours before the electronics died, I will try the 50 hour changes on this one![]()
(I'd seriously consider a Honda GX petrol engine with LPG conversion over ANY of the Chinesium diesels. Rated as a 1000 hour engine by Honda - I saw loads that did MUCH more than that. Key with LPG is keep them from running hot so very good ventilation/airflow - and mai tain a decent, smaller than stock spark plug gap.... its the only way to retard ignition for gas, & stop you burning out exhaust valves).
A petrol set is way less than a decent 3000rpm diesel with a Yanmar in it, & on lpg the running cost is comparable as well. Only bugbear is manual start is harder than on petrol - but leccy start ones no bother.
A house I owned from 1995-2001 had an attached garage which was unusual for a house built in 1928. Alas it was built for cars 7 feet tall and 3 feet wide so I could never get my Renault 25 barge in... anyway, the previous owner had a Mk 2 Cortina estate for some years (which did fit) and on a wall he'd chalked a record of all the decokes he'd performed on itConsidering the general trend towards engine reliability and longevity alongside performance, economy and cost, I wouldn't be too quick to knock engine development.
