BrokenBiker
- Newport, South Wales
I am trying to make my own version of a grease spray gun, for spraying EP type grease onto crane booms. They are available, but expensive, and I am loosely copying one I have used before, but doing so from memory pretty much.
I prototyped with a mish-mash of lube guns, air fed oilers and what not and it wants to work, but it's too sloppy of an attempt to get where it needs to be, but it has served it's purpose of showing me where the failures are.
So, I've got some ally on the way, some nice quality speed fittings, nylon pipe and a new spray head with a better trigger.
Stumbling block now though is that, while I need an air feed to the bottom of the grease cartridge, and an air feed to the trigger of the spray head, I need the feed to the trigger to be at a lower pressure to that of the grease cartridge.
This is all done via a T piece feeding the handle...I have 10 bar in the bottom through a 1/4 bap quick release, then a 4mm nylon pipe out the side to feed the bottom of the cartridge to force grease into the spray head, but I need a lower pressure in the spray head to allow the grease to actually be forced in. If the pressures matched, the grease won't move.
Am I right in thinking that if I put a smaller hole in the top of the T piece (the end that screws into the spray head and feeds the trigger) than the bore of the 4mm pipe feeding the cartridge, the cartridge pressure will still over power the pressure in the spray head and allow grease to be forced up while being sprayed out?
I am unsure if 4mm pipe is correct at the moment, but the joy of speed fittings is that the 4mm and 6mm both take an M6 hole, so upgrading later is as simple as changing 2 fittings and a bit of pipe and as I'm making the T piece myself, I can just bore the feed hole bigger to suit if needed to suit the upgrade.
This is all for my own personal use to save my back as currently doing this task stood on a ladder with a paint roller dipped in grease...rolling 48 meters worth of boom by hand is getting tiresome
