Possible one for @premmington but hopefully others as well.
My trusty Audi A4 needs rear discs and pads. No biggie for me usually, but I’ve come across a fairly bad design.
To get the rear discs off needs the caliper carrier bracket removing which is quite normal. To unbolt it is anything except normal though. The bolts, which go in from behind, they’re 8mm Allen heads and look impossible to get to without removing the entire suspension/hub assembly and putting it in a vice. I can get to the upper bolt if I remove the shock absorber but the lower one is pretty much inaccessible. Needless to say the one I could get to is super tight. I tried my Makita 1/2” drive impact, nada. Then a breaker bar which snapped the Allen key socket (US Pro tool)
I’m not keen to remove it all as that means a 4 wheel alignment afterwards. So I soaked them in penetrating fluid yesterday and will do again today. Can’t easily get the bolts hot as there are rubber bits nearby.
Any other ideas chaps?
And, where can I order a 1/2” drive 8mm short Allen key for delivery to a UK address before Friday. Needs to be better quality than the US Pro (swiss cheese) things please. Mrs DomDom can bring it over next weekend.
