Right then what do you recon will be best for preventing rust again, as you can see from the photo below. The front of my car had a fair bit of surface rust on it. Ive ground it all back now with a flap disc but the metal has darkened slighlty in the worst effected area's. so my question is whats best for covering it all? i dont want the rust to re-apear and i can t guarantee ive got to all the nucks and crannies so ideally want a rust-killer type of base coat, before spraying. Ive got about 5 liters of primer already but its just standard cellulose.
Ive read etch primer is a good base but will it prevent rust? also seen the use of red oxide? can this be sprayed over?
I've used Hydrate 80 as well, just another "rust converter" that doesn't really work! Scratch it and the rust is still there underneath, biding its time, waiting to come back and eat your car again!. It is the wax protection that is stopping the rust in your case, or at least slowing the progress of rust , for a while anyway. Wax can seal out water and air for a while.
