Currentmonger
New Member
- Western Cape, South Africa
Will the 260v setting be fine for 220v?
Any of those lying around in the dusty tray at the bottom?
You might just have to crank it up a bit more, it's basically a huge transformer, with multiple windings for different voltages.How might the lower voltage affect the current output?
I wouldn't bother personally.Should I hook up an ammeter to check?
I lay down a test bead, if it's cold, crank it up, too hot, turn it down.Should I hook up an ammeter to check?
Well, that's pretty thick in my books.Hard to say what thickness, unlikely to be more than 60mm though.
Which part of the diagram are you looking at? It quite clearly shows 220v windings.View attachment 500057View attachment 500058
As you can see it does not mention a position to run it on 220v.
I was looking at the small sticker that shows how to configure the input.Which part of the diagram are you looking at? It quite clearly shows 220v windings.
