Hi guys,
I recently bought a clarke 100e MIG to learn to weld in order to repair an old austin mini.
Im looking for advice following my first attempts at welding (0.75 mm steel).
(In the pictures - labels 1 and 4 relate to the lowest power setting, whereas 2 and 3 are at a medium setting)
Using disposable bottles of argon/co2 shielding gas.
I read the page on welding thin sheet so gave the stitching technique a go, however in each weld there appears to be a small dimple (not a porous hole) where each weld ends.
So i tried going back over the previous weld a little before it cooled completely, but i dont think it made much difference (picture 4).
Is there any way to fix this? Does it cause much of a problem?
Also there appears to be slighly more weld material/bead on the rear of the weld than the front, even on the lowest power setting, is it just a case of moving faster along the metal to fix this?
I know the welds arent great, and any advice is greatly appreciated.
Cheers
Kane
Cheers
Kane
