Hi All,
I'm helping a buddy out with his hot rod build at the minute ('33 ford if you're interested). One of the jobs we need to do is to recreate the diagonal reinforcements in the chassis. These are fairly straightforward 2mm steel C sections. The originals have ~84mm holes punched in the to save weight and provide cable/pipe routing. It's not essential to replicate them at all and certainly not accurately, but it would be nice to do so. Plan B is to buy a hole saw and get cutting, but can anyone recommend a punch tool that can deal with material this thick? I have a 10T hydraulic press and the rails will fit through it fine if that helps?
If it goes well on the reinforcements we'll probably go for the same technique on the chassis boxing plates.
Thanks
Thanks
