roblane65
- Newcastle UK
bit of a rant , well no a full on rant actually
I.ll try to be brief. if anyone s seen my previous thread about the non cranking RR here we go it's almost
certainly been narrowed to the starter motor now . So sunday afternoon being pretty mild and sunny I thought I'll get it of and drop it in to be rebuilt .
let the rant begin , trolly jack and axle stands up she goes heat shields off and a cursory look , should'nt be a problem was an understatement
the starters only on with two bolts .
now landrover ( BMW ) in their infinate wisdom put one from the back of the bell housing through to starter ( thats at the bottom ) and the other at the top through the starter back to bell housing and this is the fecker ! you can't see it and even with my tiny hands I can just about squeeze enough in between the ginormous cat exhaust manifold to feel the head of the bolt with the tip of me finger . Even the cable connections are on the side of the motor sandwiched between the starter and the block so you can't even disconnect it with out dropping it
which ever you turn spanner ratchet long long bars all seem to foul something or other . you'd thing they'd used a stater of something else and rotated it 180 degree just to f**k with you .
So if anyones done one these and got any pearls of wisdom I'm all ears
And to add to my frustration I've just had to get a new laptop and I'm having to deal with window11 it's not going well for this old technophobe
and just received a notice of prosecution for some exuberant driving bringing the new car back up from Bristol last friday . oh and the DVLA ONLINE service for a sold vehicle only works 7am to 7pm really !
Rant over and out for now I'm off to bed shortly mind I'll be up for 7 for the DVLA
I.ll try to be brief. if anyone s seen my previous thread about the non cranking RR here we go it's almostcertainly been narrowed to the starter motor now . So sunday afternoon being pretty mild and sunny I thought I'll get it of and drop it in to be rebuilt .
the starters only on with two bolts .now landrover ( BMW ) in their infinate wisdom put one from the back of the bell housing through to starter ( thats at the bottom ) and the other at the top through the starter back to bell housing and this is the fecker ! you can't see it and even with my tiny hands I can just about squeeze enough in between the ginormous cat exhaust manifold to feel the head of the bolt with the tip of me finger . Even the cable connections are on the side of the motor sandwiched between the starter and the block so you can't even disconnect it with out dropping it
which ever you turn spanner ratchet long long bars all seem to foul something or other . you'd thing they'd used a stater of something else and rotated it 180 degree just to f**k with you .So if anyones done one these and got any pearls of wisdom I'm all ears
and just received a notice of prosecution for some exuberant driving bringing the new car back up from Bristol last friday . oh and the DVLA ONLINE service for a sold vehicle only works 7am to 7pm really !Rant over and out for now I'm off to bed shortly mind I'll be up for 7 for the DVLA
