Retro Rust
- Manchester
Might be running before I can walk here but I recently bought an Rtech welder (after many years of wanting to weld) to fix up my Capri. I think this could be the perfect project once I've practiced how to weld thin metal and how I'm going to go about doing it as I'll be working outside In this area...
I thought I'd have a quick look today at the areas I know need work. Any advice or video links on how to go about these repairs would be great. The floor has started to separate from the inner sill. The sill looks solid from the top but obviously It's going to be a bit rusty where I can't see. Would it be best to angle grind the floor away next to the Sill and try to clean the Sill up with a Power File?
Here it is with an LED light under the car to show the rust.
I'm guessing this is sound deadening thats trapped a bit of surface rust. It kept chipping off and I couldnt get a magnet to stick to it. A screwdriver wouldnt go through the rust so hoping it will clean up.
Front floor has a hole in it which I guess would be straight forward.
Lastly theres a hole behind the passenger seat. Modeled by my finger.
I know it might be easier or a good Idea to by new floor pans and use what I need from them but I'm mainly intrested in knowing what to do if the Sill isnt too bad and you just want to let a bit of the floor in as I dont want to replace more than I need to to make it solid.
Also I guess it going to be a pain removing this sound deadening?
Some how the logic of grinding sparks able to melt their way into glass being unable to penetrate brown paper escapes me - only if sparks don't hit it I guess. BTW they will also make your overalls smoulder, don't ask how I know.
